Subwoofer cable?
Aviator
I have a 8" sub (Energy Take S8.2) connected thru the low level input to my receiver. Currently I'm using a regular RCA cable to hook up the sub. Will it make a big difference if I use a subwoofer cable?
Phalanx
I'd be intrested to hear about this aswell.
ABC
What you have is fine.
