SACD won't play
Dave S
I have received alot of valuable advice on this board, so now that I have all my new gear (very happy), I ran into a curious thing -
Sony ships a multi-channel SACD disk with the 555ES player (Dylan). Mine is hooked up to an NAD T763 via optical link. The disk will play in 2 channel but I get no sound in multi-channel -
Any ideas?
Username: John_a
Post Number: 138
Yes, Sony do not want you to be able to play SACD through the optical link, in case you try to copy the disc. They will never let a receiver incorporate the digital decoder/processor, unless we all stop buying their stuff, so they have no choice. They are into market control, not sound quality, and not value to the customer.
You should connect with analogue interconnects to the Ext 5.1 input on the receiver.
Username: Kegger
MICHIGAN
Post Number: 339
yes both sacd and dvd-a have to be hooked up to
the multi channel analog inputs.
as john said it's a copyright thing "for now"
