AM Tuner - Old vs. New
Username: Dscrobe
Reading, PA USA
Post Number: 58
I fixed up a tube radio from Zenith. Replaced/checked all tubes. I was amazed at all the AM stations I was picking up at night. I understand that reception is better and that some stations wait to come on till night. But, I could only pick up 1 to 3 stations on my more modern receiver.
Username: Nuck
Post Number: 8900
Daniel, be sure your receiver wasn't only looking for am stereo stations!
Good 'ol stuff ya fixed up there.
Username: Dscrobe
Reading, PA USA
Post Number: 59
Yeah, it has FM and FMC. The FMC works better than the FM selection. It seems to lock in on a station, once you tune near it. You could move the dial and you won't hear any static until it begins to lock into the next station.
Username: Jan_b_vigne
Dallas, TX
Post Number: 11541
AM Stereo?
DS - Most modern tuners consider the very limited frequency range of AM broadcasts to be unworthy of serious attempts at quality reception. If they concentrate on tuner functions at all in a receiver, they will favor the FM side of the dial. I suspect the old tuner had a ferrite rod for the AM antenna. What sort of AM antenna were you using on your "modern receiver"?
Username: Dscrobe
Reading, PA USA
Post Number: 60
Not stereo. Only has one 8" 8 ohm loudspeaker. For the modern receiver, I use the standard 6" dimeter wire loop that came with it. Looks like it has only five turns at the most.
Dallas, TX
Post Number: 11553
The loop antenna is meant to be removed and positioned for best reception. That might slighty improve your station count. Or, you could try a very long wire whip antenna placed as high as possible. A run across the backyard is usually sufficient (make sure it's earth grounded if you try this). But, the highest probability is your receiver just doesn't do AM very well.
Username: Exerciseguy
Brooklyn, NY United States
Post Number: 1424
I don't know if you've seen this http://www.sixmoons.com/audioreviews/tubetuner/r601p.html thing, but it looks pretty neat.
Jan, why have manufacturers abandoned the ferrite rod design?
Dallas, TX
Post Number: 11634
People used to use them as handles and then get p!ssed when they broke their new component.
Post Number: 1427
I suspect you're not kidding.
I get terrible AM reception, I'm getting interference from outside my apartment and have been unable to remedy the condition. Currently I'm only using the stock plastic-rectangle loop antennas, but I've considered picking up one of these http://www.ccrane.com/antennas/am-antennas/index.aspx , any thoughts?
Need to Register?
Forgot Password?
Enable HTML code in message
