Steve | I have just bought a new Pansonic SC-EN5 mini system but i want to connect up different speakers to those supplied with it. I already have some off my older system (Aiwa XR-M11). The connectors for both sets of speakers are the same but i'm just not certain if the two makes of gear are compatible. Any help on this would be appreciated! |
New member Username: EdisonPost Number: 25 Registered: 12-2003 | Check the ohm rating on the speakers, and if they match, you should be fine. Some systems do not work with 4 ohms - only 8 ohms. |
New member Username: Mark_of_cenlaPlaucheville, Louisiana USA Post Number: 4 Registered: Jun-04 | I connected my old Philips speakers from my old mini system to my new Sony mini system, and it sounds much better. |
Anonymous | I took 2 old speakers from my car and i'm trying to wire them up to my mp3 discman but it's just not working how do u suppose i come about this? |
Anonymous | would the sony speakers SRS-A27 work on my Sony Atrac3plus MP3 CD Walkman D-NE511 |
Unregistered guest | i took 2 old speakers out of my car and tried connecting it.but the output is very very low.do i have to connect an amplifier.the speakers i have used are of 4 ohms. |
dimsum_ph Unregistered guest | always follow the speaker rating, you should never used one that is lower than what is indicated. If it says there 4 ohms, don't use speakers below that rating or you will be wasting power. |
DANNYDANNY Unregistered guest | i have just bought a new technics system, and i want to hook up also my old sony speakers to it, so there would be 4 speakers overall. BUT there is only an input for both of my new speakers, so i have nowehre to connect my old sony ones, how would i go about connecting these? any suggestions would be appreciated. . danny |
Anonymous | I've got some old Electro Voice SH-1512 night club speakers. They have 1/4 inch jacks. Is there any way to hook that up to any of the newer stereo recievers? My amp is going out. |
New member Username: GriefPost Number: 2 Registered: Apr-06 | DANNYDANNY there is a way using the b-tech 's bt12 loudspeaker switch. it will allow you to connect two pairs of speakers and listening to them separatelly or at the same time. Here is a helpful link http://www.hifileads.co.uk/website/access/btech-bt12.htm it 's quite unexpensive. |
