HELP with cut off frequency
I have a sony str-de885,in the advanced settings are cut off frequencies, does anyone know what the standard settings are or where I should start? I also have it connected to a sony subwoofer, what is the setting for the reciever/ cut off to the sub?
THX certification states 80hertz for the satellites to hand off to the sub...if memory serves.
Depending on your satellites, you may want to crossover a little higher, like 100 or 120 hz. Try them and listen.
-h1pst3r
