New member Username: Matt_b_21LondonUK Post Number: 1 Registered: Nov-04 | Hi im getting the Technics SCDV290 DVD Mini System. I have 2 other speakers that i would like to add to the system... im not sure if anyone here has this system.. i just wondered if the stereo has room for more speakers to be added. the speakers i have, have 2 wires coming out from each of the speakers - so theres 4 wires all together with copper wire (i think)(gold i would appreciate it if i could be emailed about this question at mi5_21@hotmail.com |
New member Username: Matt_b_21LondonUK Post Number: 2 Registered: Nov-04 | ahh these speakers are panasonic and are like 4 to 5 years old |
New member Username: Matt_b_21LondonUK Post Number: 3 Registered: Nov-04 | Hey.. i did some research and found a switch box.. i think that does the trick if i dont have extra stero out puts... is that right... i read in anther thread that depending whether its 4ohm or 8ohms depends whether the speakers will work wit the stereo,, if they didnt... would they work if i used a switch box, as i would be connecting the speakers to the switch box not the speakers.. is that right? |
dimitris Unregistered guest | is there a manual about technics SCDV290 DVD in English or greek |
