Advice needed
Just purchased a Yamaha RX-496 receiver.
when hooking up to my Baby Advent II the volume is very low. The loudness control is turned to flat and still no sound. When you turn the volume up, almost full tilt you can here just a slight sound. HELP !
Are the baby advents a 4ohm speaker (I would be surprised).
Not sure if the Yam has an impedence switch on the back (some do) but you may want to switch it to 4 ohm AFTER checking what the nominal impedence is of your speakers (usually on a little sticker on the back of the speakers which would say either 4, 6, or 8ohm, the higher the number the easier for the amp to push).
Good luck,
-h1pst3r
