Paradigm In-Walls vs. B&W
Username: Redstripe
Looking at Paradigm vs. B&W. Which is the better set up?
Paradigm - ASM 250 (wall), CS 80 R (ceiling), CC370 (center), and PDR-10 ($1,500)
or
B&W - CWM650 (wall), CCM65 (ceiling), LCR60 (center), and 10" sub ($2,000)
My budget for the speakers is $1,500-2,000. Does anyone have another recommendation?
Thanks.
Username: Bezel
Post Number: 25
Are you sure you want to have in wall speakers?
I did not hear Paradigm in wall ones, but I do know how B&W CWM 650 sounds.
Actually they are not bad, but not so good as usual 60x series speakers (for the same money).
So, take into account that for the same money you can get better speakers then in wall ones...
Username: Redstripe
Thanks Bezel. Yes, I do need in-wall/in-ceiling. The wife gave the okay on speakers so long as they don't appear in the room. So, in-walls or nothing is my choice.
Using a Denon - AVR 1801.
Username: Bezel
Post Number: 26
Ok.
If you do not plan to change the wife, then get in-wall speakers :-)
