Would you pay $50 for Infinity Reference Three Speakers
Username: Duckmanx
Post Number: 26
Just debating this offer...
I cant find too much info or reviews on these speakers, except this...
http://www.infinitysystems.com/homeaudio/product_detail.aspx?Prod=CS993002&cat=& sType=
I currently have my Center and Surrounds at 8ohms, would it be alright to mix different speakers with different ohms on my receiver (it accepts both). It says exactly...
Front A OR B 6-16ohms
Front A + B 12-16ohms
Center 6-16ohms
Rear 6-16ohms
R. Surround 6-16ohms
The guy selling them has upgraded to $1600 Paradigm towers
Thanks.
DuckmanX
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 851
Should be okay in terms of impedence. What receiver is it?
Username: Duckmanx
Post Number: 27
It is a denon AVR485
Username: Duckmanx
Post Number: 28
Are the speakers even worth my 50$
Post Number: 853
I'm not sure exactly what model they are, but $50 for a pair of speakers isn't very much!
Are you asking if they will do? (Sure) Or if you could do better for $50 (probably not) or better for $200 (probably).
The only Infiniti Reference speakers I seem to google are car speakers!
Username: Audioholic
Post Number: 59
Those are old Infinities. RS 3B's perhaps? HUGE honking things? Do a search for vintage Infinity speakers. There is a web site.....you'll find them there, i'm sure. Expensive back in the day, but better quality speakers exist today for less $$$. If you like em, buy em. Infinity was a 4ohm speaker though, so they might make your amp run warm.
Post Number: 863
The web page (without a picture) said 6 ohms.
