kaleb Unregistered guest | Someone please reply to this... I have a JVC shelf system, like a home stereo or whatever...I was wondering, can I buy subwoofers that are made for cars, the kind that already have a box, and hook them up to my home stereo? that would be awesome to have subs for a car in my room. please reaply asap and if its possible could i have some simple instructions :D For Example, Could I hooks these up to my home shelf system... http://www.bestbuy.com/site/olspage.jsp?skuId=7044085&type=product&productCatego ryId=cat03081&id=1099396976115 Please dont use weird terms, i know nothin bout speakers lol, just put it plain an simple |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 4016 Registered: May-04 | No, with a shelf system, you can normally only use the speakers that came with the unit. |
Lester Unregistered guest | If your shelf system has detachable speakers and you can get to the speaker wires, then in theory, there's no reason why you couldn't add a sub. However, you will need a powered sub to do this. An inexpensive JBL or Yamaha with speaker in and out connections would do it. If you want a car sub for its looks, then you'll need an amp to drive it. This means the amp has to accept speaker level since you system probably does not have any type of line out. A sub amp can be found here: http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=3&filter=subwoofer+amp lifier&tempfilter=plate+amp&sm=1&so=1&raid=1&rak=plate_amp Be sure the amp and sub are compatible. Save the boxes incase you need to return items. |
kaleb Unregistered guest | http://www.amazon.com/exec/obidos/tg/detail/-/B000066R71/103-2723137-9539847?v=g lance Thats the Stereo I have, http://www.bestbuy.com/site/olspage.jsp?skuId=7044085&type=product&productCatego ryId=cat03081&id=1099396976115 thats what i want hooked up to it...I have optical [digital] out...I dont know if i need that or whatever, but is it possible? |
kaleb Unregistered guest | The Speakers are detachable... |
Silver Member Username: EdisonGlendale, CA US Post Number: 624 Registered: Dec-03 | It's possible but I wouldn't do it - the sound will not be better. The JVC already has pretty good bass - if you want better sound, you want to go with seperates - separate receiver, CD player, and speakers. Trust me, you would not be happy with the result. |
