Akai amplifier
I have found an old Akai amplifier at a second hand shop, but it has no price tag on it. The model is AM-U11 and it comes with a receiver, model number AT-K11. I was hoping someone could suggest a reasonable offering price for it so i don't get ripped off.
it has 3 input channels, aux, phono, tuner, and i couldn't find a wattage output reference number on it.
Any help would be appreciated! thank you!
Username: Lockaudio801
Post Number: 93
LunaCrist,
After testing that unit and finding it to suit your preferences then I would suggest you offer to buy it for $20 dollars tops. Make sure everything works ok.
mik
hi!
there's one am-u11: http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=3811764370&category=22509
but it seems really old, too old for a receiver, is yours like that?
i just ask you because i intend to buy that one, just because it looks nice
LunaCrist
Yes that is exactly the one. I found out the inputs don't work but i'm having an electronics friend of mine looking at it. Hopefully it's just a couple of loose wires.
Ya $20 bucks sounds right up my alley..thanks guys!
LunaCrist
Oh and that's actually the amp not the receiver FYI.
mik
have you tried it yet? how is the sound and what speakers do you use?
before i misunderstood receiver with remote...
Username: Project6
Post Number: 503
prone to pops and hiss at its age...nice during its day.
