Like
Vibrapods = Best Cheap Upgrade!
Username: Artk
Albany, Oregon USA
Post Number: 605
Little outlay, big return. You want to improve your sound for very little dough, pick up a set of pods and use them on your cd player. I am using them on all of my gear. Makes a big differnce. Lowers noise, increases dynamics, enhances and deepens soundstage. Presentation is more 3 dimensional and life-like. Cost $5-6 per pod or $20-24 per component. Great perfromance enhancing drug for your system.
Username: Jan_b_vigne
Dallas, TX
Post Number: 3910
The units with the captured ball bearing is a substantial upgrade. They are to be used either alone or with the original Vibrapods.
http://www.audioadvisor.com/store/productdetail.asp?sku=VIBRACONE
Username: Edster922
Post Number: 687
art,
I can see this making a difference with any components that have many continuously moving parts like turntables, cd/dvd players, tape decks...but how would it improve SQ on a more inert component like an amp/receiver?
Dallas, TX
Post Number: 3915
Do power transformers not vibrate, eddie? Do you believe only components which move are susceptible to outside feedback?
Username: Artk
Albany, Oregon USA
Post Number: 608
Precisely.
Username: Rick_b
New York USA
Post Number: 1156
May I also suggest Mapleshade brass isolation cones. I use them under all my components. Highly recommended. www.mapleshaderecords.com
Username: Edster922
Post Number: 698
jan,
LOL i really don't believe you can be that obtuse, but since i would feel really terrible to leave so many wrinkles on your forehead:
Art, do you hear as much of an improvement using these pods on components with vibrating parts (receivers, amps) as opposed to components with SPINNING parts (e.g. a CD player)?
Dallas, TX
Post Number: 3925
Obtuse is as obtuse does, eddie!
Username: Edster922
Post Number: 700
yes indeedy...
Username: Artk
Albany, Oregon USA
Post Number: 609
Every component that I use them for results in improvement. Very small investment for big returns Edster.
Facebook
Shop Related Deals
Directory
