DVD Surround Audio -> Receiver - Not Working
Jack Bauer
Hello,
I'm using an optical audio cable to connect my DVD Player to my Denon AVR-485 AV Surround Receiver. However, the sound is not coming out properly when on Standard Surround Sound Mode. Only two speakers are active, the sound is very hollow - I hear the background sounds, but I hardly hear the foregrounds sounds like voices, etc. If I set it to 6Ch stereo mode, the sound is fine, but naturally I'd rather use surround sound mode. Could anyone help me out here ASAP (I need my 24 fix)?
Thanks
Username: Dmwiley
Post Number: 547
Check the audio set up on your DVD player.
Jack Bauer
DTS and Dobly Surround are enabled.
Jack Bauer
bump - I have no idea how to fix this.
