Receiver
Username: Gobux42
Toledo, Ohio USA
I just had a professional wire my new home for sound. I will have 5 speakers in the living room. I was looking at getting the Yamaha HTR-5860BL with the Athena MICRA 6 speakers. The room is 14 by 16 and has carpet. Is this a good choice?
Username: Edster922
Post Number: 381
Depends...what's your overall budget?
How much HT and how much music?
Have you already bought the Micra or is that just under consideration?
Username: Gobux42
Toledo, Ohio USA
just a consideration. i heard good things. I would like to stay under 1000. it would be a balance that leans towards the music side.
Username: Edster922
Post Number: 388
Under 1000 for just the receiver or for the whole setup? And do you plan on having a sub?
