CONNECTING SUBWOOFER
Username: Vblach
North Vancouver, B. C. Canada
I have a Pioneer VSX-454 receiver and I want to
connect a Yamaha subwoofer YST-SW015 to it.On the
back of the Pioneer it has only one Pre-out for
a subwoofer.In the owners manuel for the Yamaha
under "connections" it has a note stating that if
there is only one Pre-out do not connect the
subwoofer. How can I connect it up.
Thanks for any help
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 417
That doesn't make any sense. It has line level connections made for the receiver pre-out. Go ahead and use the RCA input on the sub.
Username: Vblach
Thanks Peter,that worked fine.
Thanks for the help.
Vic Blatchford
Post Number: 421
They probable meant that you shouldn't use an all-frequency pre-out like you'd find on a pre-amp to feed an amplifier and then speakers (i.e. do feed the sub anything over 200 Hz or so).
What you have done is fine. Glad it worked out for you.
Username: Vblach
Thanks again Peter
Vic Blatchford
