Looking to get rid of media center
Lt Mac
I have a Bose Lifestyle 35 system. (Never saw this board 3 years ago when I bought it). My question is this: Can I get rid of the media center and put in my own reciever and DVD player but keep the acoustimass module and speakers? It seems to me that there is a proprietary connection from the media center to the module. If it is proprietary is there anywhere I can buy an adapter or whatnot?
Thanks in advance
Username: Project6
Post Number: 2969
You may be looking at this at the wrong angle. The problem lies not in the media center but the speakers. You may want to think of getting new speakers and then replace the media center.
However, if you want to change the media center and keep the speakers, you can always remove the speaker connections and use the bare wire to connect to your new receiver. The sound, however will not improve.
You can always sell the Lifestyle and start from scratch. The Bose will still fetch a good amount so cyou can use the proceeds from its sale and get a new system. There are people that really love Bose, I'm sure a lot of folks on ebay will gladly take it off your hands.
good luck:-)
Username: Edster922
Post Number: 245
Berny's right on. Doesn't the Lifestyle go for upwards of $2500-3000? You should easily get $1000 for it on eBay.
Even the $500 Onkyo 770 HTIB is sure to sound ten times better.
Username: Edster922
Post Number: 246
Even the $500 Onkyo 770 HTIB is sure to sound better.
