Connecting components
We have a Mitsubishi ws-48315 tv. Can you tell me what is the best way to hook up components. I an air antenna, also need to hook up satellite and vcr with another line going out to bedroom tv? Can you also provide diagrams?
Username: Pratiram
La habra, Ca U s a
I have a pioneer recever, Prosca 80 series TV.i am trying to attach my DVD withis system. I am not sure what channel is my DVD input on my proscan TV .Can any one help?
Username: Natish
India
Post Number: 17
desai,what dvd player ur havin.Rear panel of TV will have composite video(yellow socket),S-video(black) or Component(Red,green,blue) inputs.Connect the same to the DVD player.For audio connect white and red (Left and Right) to the tv from the player.Change the input thro tv's remote.
Username: Paul_ohstbucks
Post Number: 599
Steve,
There is no right or wrong way, and you can accomplish your goal any number of ways. It depends on your output/input combos......
Take a close look at what you have, and the solution will present itself. It's not really that difficult.
