Did I blow my amp?
lkjafsflklk3ndlkn3
I have a 1200w amp 4ch wired up correctly it was running fine....
Tried to brige up 2 channels to get the sub rolling and after switching out the outputs back n forth cause of havn't no sound (while music was playing) and then outputs, then tried to bridge.... The power light stopped coming on.. Left over night still nothing...
Can I check anything?
P.s. Did check all fuses and inline-fuse. Also tapped 12v to ground and got sparks. (checked fuses after that.)
Username: Thumper
Richmond, VA U.S.A
Post Number: 38
Some amps arent ment to be bridged. You can take it to an car audio store nearby and ask them to test it for you for free. Did you try to hook the amp up the way you had it before? make sure the remote wire is connected right
Username: Touche6784
Post Number: 270
ice, i think people here would appreciate it if you could leave your car audio discussions in the appropriate section of this forum. thanks
