Total newbie, need help plz with subwoofer prob
Matt Charles
Hi there, I'm new to all this and have been using my home theater only once in a while for 1 year now. I have the JVC rx-5030vbk and everything worked great until this week. I know my subwoofer works because the power switch is green (On) and that it makes sound when I pu the cables on my fingers. The thing is that on my receiver it says NO SUBWOOFER when I try to turn it on.
I didn't modify anything from the original model, but 2 of my speakers broke 3 weeks ago because I put too much base into them. Could this be the problem? If I'd disconnect the power cable of the receiver, would it reset every settings so that it might work after?
I can't thank you enough for all your help,
Thanks
Matt
Check your JVC's channel levels. You may have somehow fooled it into thinking there is no sub connected. Manually adjust each channel level/volume.
mz
