Playing MP3 Through a hifi?
JayGreen
Hi, I am a bit clueless about portable MP3 players. Can you play a portable MP3 player through a hifi? If so, what connections/leads are needed and what sort of hifi is needed? Can you do it through AUX?
Thanks
Username: Project6
Post Number: 3921
You need to get adaptors for your particular mp3, whoever makes your player will have accessories for those things that you want to do.
Yes you can do it through AUX.
quote:
"what sort of hifi is needed?"
You're kidding, right?
JayGreen
What I meant by 'what sort of hifi is need?' was do i need one with aux or some special port for mp3 players. Not all hifis have aux, and some newer ones have newer ports.
Thanks for your help,
Jay
Username: Project6
Post Number: 3939
Nope, you don't need one with auxillary ports but it may come in handy. All you need is an extra audio input (no phono) and the adaptor that I was referring to.
Good luck!
