Matching Speakers Necessary?
Username: Jkwis
I am buying some Canton fronts and center for my home theater system and going to have some in-ceiling speakers for the rears/surrounds. Do I need to stick with Cantons for those also or could I go with a different brand? My local retailer recommend some Proficient in-ceilings (C870 LCR's)since the tweeter pivots and the woofer is angled. I just want to make sure having 2 different brands wouldn't compromise the sound quality. Thanks.
Username: Jet2001
Post Number: 34
In my opinion, having the front speakers timbre matched is necessary. The surrounds are important to be timbre matched if you want the integrity of your surround sound to be perfect, but I don't think it is necessary.
My surrounds are not timbre matched to my fronts and center and I can not hear any difference.
Username: Edster922
Post Number: 51
I agree with Jet.
The only time it'd be necessary to brand match your rears is if you listen to a lot of surround music on SACD or DVD-A.
