SUB ADVICE
Username: Db18
Post Number: 17
WHAT TWO OR THREE COMBINATION WILL WORK BETTER WITH MY AMP? I HAVE A ROCKFORD FOSGATE TYPE RF XR RATED AT 700 W x 1 @ 4 Ohms RMS 1100 W x 1 @ 2 Ohms RMS. I'M OPEN TO ANY SUGGESTIONS.
I've got a digital home receiver with a LFE output for a sub. I purchased a sub with the RCA inputs and outputs, but it doesn't designate a line for LFE or mono. I've tried the Left input for mono, but I get nothing. Would it be wise to put a Y connector on to combine the R and L into one channel? Any other suggestions, please!
Username: Artk
Albany, Oregon USA
Post Number: 156
If your receiver has pre outs use the the front L-R preouts and tell your receiver that you don't have a sub. Sounds better than using the LFE.
