Speaker repair?
Neil537
I have a pair of Mission 732 speakers of which one appears to have blown. I was wondering if anyone knows of anywhere in the UK i could send it to get repaired, or can I buy parts and do it myself (I am an amateur at hi-fi stuff though!)?
Any help or advice would be greatly appreciated.
Cheers,
Username: Paul_ohstbucks
Post Number: 867
Neil,
I would try finding replacement parts though the Mission website. If you cant find what you need, shoot them an email and they'll let you know where you can find the parts you need.
Replacing woofers/tweeters is very simple. Simply unscrew, remove, unplug, and replace. Just be sure to mark the posts polarity so you dont plug the replacements in backwards. My advice would be to order replacement speakers, and install yourself. It will only take you all of 2 minutes to make the swap.
