Mirror Audio CD
Username: Phairoj
Is it possible to make an identical copy of a audio CD? (all the audible and non-audible infomation are completely identical).
My Sony SCD-XB940 cd player refuses to play a copy of audio cd made by using CD Burner!!
Yes, use pro recorder
Username: Phairoj
Could you be more specific. Which "Pro Recorder" do you mean?
Thank you,
Need to Register?
Forgot Password?
Enable HTML code in message
