Websites for Audio Furniture
Anyone know of any good ones? Looking for upscale type furniture and many options for my odd space. Thanks.
Username: Gman
Post Number: 232
There are a lot of companies. In the upscale realm there are a few--AVDeco, Bell-O, BDI, Furmiture Works, Tech Craft are some of many brands.
I particularly like Bell'Ogetti Italian furniture. They make some truly beautiful modern pieces. But all the above make quality funiture that is a cut above most, although I am sure I left out plenty.
You need to do a google search on at least these companies websites and get them to mail you a catalogue so you can get an idea of what they make and so you can find out where you might buy them locally, or not too far away.
Only you know what you like, the dimensions you need to fit your components, and the dimensions your room will tolerate.
You might call or e-mail them for modular options.
Username: Igorzzzz
Look on www.audiolinks.nl
Browse trouhgh the alfabet and scroll down untill you see "furniture and stands"
Plenty of links
