What you think of this???
Username: Yamahaboy
Orland Park, Illinois USA
Post Number: 50
hey everyone, as some of you might know i have had some amp problems with my pioneer head unit. it has been reading "amp err" after a second or to after turning on. I am going to buy a new reciever and dont know exactly what to buy. i have no more then $200 to spend and dont wanna buy something crappy. i was looking at http://www.circuitcity.com/rpsm/oid/90107/originURLEncoded/http%253A%252F%252Fww w.circuitcity.com%252Fccd%252Fcategory.do%253FcatOid%253D-12949%2526N%253D200128 98%252B20012949%2526c%253D1/rpem/ccd/productDetailReview.do#tabs (sry do know how to hyperlink) but dont know about it. and no i would not buy from cc. please let me know. a pic of my room with a list of what i have is under "bragging area" but i cant get in there for some reason right now. my aim is blownprix99 if you need to know anything els..thanks again for the help.
Eric
Username: Yamahaboy
Post Number: 51
does ANYONE know????
Username: Kano
Post Number: 409
Sony makes crap audio products IMO. High distortion and a thin tinny sound plagues the low-end models. While the ES line performs better, I find the cost/performance benefit doesn't add up when comparing to competitors.
The Pioneer 1014Tx is a stronger performer within the same price range.
If you found your previous Pioneer's sound too flat take a look at the Yamaha HTR-5790 or the RXV line preferably.
Marantz also makes good receivers at that price point. Take a look at the 4400.
edster922
I agree with Kano, non-ES Sony receivers suck big time. Their DVD/CD players aren't too bad though for the money.
If $200 is your absolute limit then you'd be better off going with a refurb Onkyo 502 from ecost.com for $190.
The Pioneer 1014 would be much better but around $350-400.
Username: Yamahaboy
Post Number: 52
yeah 200 is about it because my parents are going to replace the one that is broke (it was there and we switched recievers) this is the equip i got https://www.ecoustics.com/electronics/forum/system-showcase/68928.html
edster922
OK, then do the Onkyo, it'll still be way better than a Sony.
