Small Room, Computer, Bookshelf Speakers
Murdah
I've read a lot of threads where the OP wants recommendations and I know how important personal preference is, but I need direction.
Here's the rundown:
College student, dorm room, computer, MP3s, DVDs, rock, classical, Creative Extigy soundcard (integrated on-board audio), and $500 budget for powered speakers or an amp and a nice set.
I have a Cambridge Soundworks 215d system now, but it's 3 years old and starting to crackle, hiss, and there are some frequencies that've somehow become harmonic for the enclosure. I'm tired of having a bass cube and weak sats because the balance is different everywhere in the room and at every volume setting.
So, I'm looking for bookshelf speakers that won't need a sub, but I'm still open to a good sub/sat set. I don't see many choices for powered speakers, but if I go for an amp and speakers, I don't even know where to start. I see the Epos ELS-3, the CSW M60, the RB35, and some other contenders. I want good quality of manufacture and good service, and great sound.
So, where else should I look? And, if I need an amp, where do I go? Show a newbie the path.
Username: Tevo
Chicago, IL USA
Post Number: 112
You won't get full range in bookshelves under $500. Technically, no bookshelf offers full range (i.e. extension down to ~ 30Hz with no audible sound roll off). Just not physically possible.
NHT's M-00 are self-powered but they are also not full range. You'll have to add a sub (like their matching S-00).
http://www.nhtpro.com/2004/products/product_index.asp?ProductLineID=1&SubjectID= 1
http://www.listenup.com seems to carry these and other NHT retailers ought to be able to special order them but their recent exposure might make these excellent mini-monitors more mainstream.
Username: Hailandkill
Post Number: 11
Actually, you can pick up a pair of the Event TR8's at your local Sam Ash for $500. Link:
http://www.samash.com/catalog/showitem.asp?SKU=ETR8NPAIR
They can go all the way down to 35Hz, which should be enough for a dorm without getting any noise citations ;). They are also self powered, and bi-amplified, meaning the tweeter has a seperate amp from the woofer. Sam Ash should have them out and ready to be auditioned. Give them a look. Good luck!
Murdah
I went to the NHT site and immediately started drooling over their other speakers...the M-00's seem nice, and the reviews I've read are positive.
The TR8's look interesting too; I've found some glowing reviews. I'll have to check both of those out at the local hi-fi shop, if they have them.
Any other contenders?
Murdah
Also, what do you think of Aperion 522d's? Would a pair of those and an amp be good?
They certainly *look* good.
edster922
check out this thread, the OP was in a similar position to yours:
https://www.ecoustics.com/electronics/forum/home-audio/125152.html
You may also want to experiment with the Logitech Z-2300 system, and save your money for a much better quality starter system (budget at least $1000 for 2-channel) afterwards. Ample power for a small room: 40wpc sats and 120wpc sub, the most I've ever seen in a 2.1 PC system. I use the Logitechs in my home office and they are surprisingly good for the money---got mine for under $70 with rebate.
You can buy the Logitech at a CompUSA and return it if you hate the sound.
edster922
Another option for a dirt cheap 2.1 system:
http://www.amazon.com/exec/obidos/tg/detail/-/B0000C2KB7
From the reviews and specs, this sounds like a very good system as long as you don't crank it too much.
