Use your telephone to burst eardrums?
Username: Wa739
Hi, does anyone know if there's a way you
can use a telephone to burst somebody's eardrums?
Like can you call them, and then when they answer, you put your phone near a very loud speaker and turn the volume all the way up?
Would that work?
Username: Kano
Post Number: 354
No, the telephone earpiece really doesn't have much of an amplifier in it.
You will have to think up a new attack plan.
Username: Touche6784
Post Number: 174
what are you five years old?
virkon
Blow a whistle with all your might. Is someone bugging you? Might be better to report it to the phone company.
virkon
Blow a whistle with all your might at least you won't damage your speakers! Is someone bugging you? Might be better to report it to the phone company.
