Which Receiver???
Looking to upgrade my HT but can't decide on the receiver. Looking to spend a max of $800. Have had three Denon's and have never had a problem and am considering the 2105 and 2805. Majority of use is watching movies. Speakers area Polk RTi800, Csi300,Fxi300 and Velodyne sub.
Any recommendations??
Username: Dloweman
Post Number: 99
If you like the sound of denon and have never had a problem with them, then definately stay with the denon's, I think the 2805 is a great receiver, a step up from the 2105. Also if you are looking for a change, check out the Pioneer Elite 52tx as it is about the same price range and will match well with the Polks.
