AR5 vs Def tech 2004 or 2002s?
Username: Djtorch
Post Number: 25
Hello, I'm trying to decide between the above mentioned speakers. Please let me know your thoughts.
depending on budget, the DT 2004TL are good but no bi-wiring and only one input for sub while 2002TL is tri-wireble and 1 input for LFE and 1 for left and right full range ( use a Y cable for this input and produces a lower bass and will surely rock you ).
Username: Djtorch
Post Number: 30
Thanks for the info. How do the Def techs compare with the AR5?
unfortunately, I never heard of it
sorry!!!!!
