How do you?
Hey all I have several Mini Disc players but I can not figure out how to play one song with out programing a play list or having to hit stop right after it.
Do you have any tips to pass along?
jaykayess
Method 1:
Change the sequence of the tracks using the edit function. Place the song you want to play as the LAST track on the disc, e.g., number 12. Then use your numeric keys on the remote (or the jog dial on the player) to key in track no. 12 and hit Play. The player will stop after the last song is over.
Method 2:
Use the "A->B repeat" function to mark the beginning and end of the track. It will continuously repeat between points A & B.
Hope that helps.
sonyericsson
I have a sony MZN1 portable netmd recorder and sometimes i get a song i am particularly obsessed with, i'd hit repeat then playmode, that gives me repeat that one song. even if it's at the end of the disc, when it finishes, it will replay that same song.
Need to Register?
Forgot Password?
Enable HTML code in message
