Damn good receiver !!!!!!!
zyman
which one is the best:
1. yamaha RX-V750
2. onkyo TX-SR602
3. marantz SR5500
4. ?????
Username: Frank_abela
Berkshire UK
Post Number: 313
zyman
Try asking this in the Receivers forum...
Regards,
Frank.
Username: Falp
Portugal
Post Number: 134
The best? Marantz sr5500!
The second? Denon 2105.
Username: Gavincumm
Post Number: 25
If you REALLY want the best reciever... throw in B&K, Rotel, NAD and brands like that. I am not sure if that is what you are after though. These will STOMP anything that you have mentioned, but come at a price of entry level seperates.
Username: Gavincumm
Post Number: 26
What is your budget?
fiddlyD
which one of those would you recomend for 95% movies???
Username: Dloweman
Post Number: 81
Definately the yamaha for 95% movies, they have lots of DSP modes and are very good at bringing you into the movie.
Username: Falp
Portugal
Post Number: 136
Denon 2105 for 95% movies
jmgillespie
Go to a ht store and listen to a few different recievers use the same speakers with each reciever and try to get decibal output as close as you can then decide. If you can't tell the difference go with the cheapest one with the features you want. If you can tell a difference look at that recievers brand name entire line and see which one has all the features you want and get that one. It's all up to what you hear. If you can't go and listen to them right next to each other just pick one with all the features you want in your price range and I'm sure you will be happy with it, all the reciever's mentioned so far are respectable brands and are known for quality products.
