Anyone heard the PSB Platinum C2 center channel?
Username: Poway_av
I'm considering going with a PSB Platinum C2 instead of the PSB Stratus C6i for my center channel. Has anyone been able to compare these, and if so, do you think the C2 is significantly better than the C6i?
I have PSB Silveri's for my front with a SubSonic 7 sub. Would there be an issue since the C2 is the Platinum line and my other speakers are Stratus line (i.e. don't match up well timber wise)?
Thanks
