Can't get my turntable to work with a Sony STR-DE597 receiver.
Username: Amdphoto
Wright City, Missouri USA
My new Sony Receiver, model #STR-DE597, does not have a phono input. Is there any way to make it work with the Sony receiver? I currently have it plugged into the MD/TAPE option. Any ideas. I have four pair of speakers, my surround sound and CD player all working but really don't want to have to get another receiver so I can play the turntable. Thanks for any help.
Username: Usa2k4
Post Number: 68
You can find a phono preamp for as low as $16 from www.amazon.com .
Username: Amdphoto
Thanks Kevin.
Username: Amdphoto
Thanks for the help.
Username: Amdphoto
Well, I went to Radio Shack and bought a preamp for the turntable. You can now hear the albums when they are playing but it sounds terrible. My husband said he wouldn't listen to his albums if they sounded like that. Any suggestions? Or is terrible the best sound we can expect using a preamp? Thanks.
Username: Usa2k4
Post Number: 73
What do you mean by "terrible"? :-)
Even though vinyls don't sound as clean as CD's and cassettes because of the surface noise and scratches, they will sound decently good with a good cartridge. I've check the RadioShack phono preamp on its website and I believe it works equally well.
Username: Usa2k4
Post Number: 76
Your preamp may be defective. I don't particularly like battery powered preamp. You can get 1 with AC adaptor from this link: http://www.amazon.com/s/ref=nb_ss?url=search-alias%3Daps&field-keywords=phono+preamp&x=0&y=0
Also, is your turntable MM or MC type? Most of these preamps are for MM type only.
