Yamaha HTR-5760 vs. Kenwood VR-8070
Username: Joeyn
Hello,
I'm looking into buying one of these a/v receivers. One feature that is luring me to the Kenwood is the THX processing. They're both around the same price range, but I was wondering if anyone knows which one of these would be a better fit for my speaker system:
Klipsch SF-1 Floor speakers
Klipsch C-2 Center
Klipsch ss.5 Surrounds
Sony WX700 sub
Or would anyone suggest a better receiver around the $300 range?
Any input would be much appreciated. Thanks
Username: Joeyn
I forgot to leave the specs on these receivers.
http://www.pricegrabber.com/search_compare.php/?topcat_id=2&page_id=73&page_id=7 3&masterids%5B%5D=2672121&masterids%5B%5D=3064206&Compare+Selected+Products.x=40 &Compare+Selected+Products.y=9
http://www.kenwoodusa.com/product/product.jsp?productTypeId=55&sortBy=price&prod uctId=2612
http://www.yamaha.com/yec/products/HTIB/HTR5760.htm
Username: Project6
Post Number: 2624
Okay, I'll say it!
I like Kenwood and this particular model is really great when mated to the Klipsch.
To be fair I used the RF-35, and the Kenwood loved driving those things. And no it did not sound shrill at all.
Username: Joeyn
Thanks for your input. I haven't heard too much about Kenwood, but I was drawn to the specs and THX processing. Yet I hear so many good reviews about Yamaha receivers including the one I am comparing. Berny, could you tell me what features you liked about the Kenwood vr-8070? Thanks again!
Username: Project6
Post Number: 2653
That particular Yamaha makes the Klipsch sound a little too harsh for my taste. I judged the Kenwood because it sounded better than the Yamaha, plus a better price. Featurewise, I think the Yamaha is better. The THX logo was not a selling point for me.
Username: Joeyn
So do you think I should go with the Kenwood? Or is there another receiver that you prefer in the 2-300 dollar range that would go good with my klipsch speakers?
Username: Project6
Post Number: 2657
For that price range I would go with the Kenwood. A lot of bang for the buck.
