Aragon Amps?
SkieS
I've noticed no one has even mentioned Aragon amps. Is there anything wrong with them? I only know about them because they are on Klipsch's website.
Username: Tevo
Chicago, IL USA
Post Number: 100
Don't think there's anything wrong with the per se. But it seems ever since Klipsch acquired Mondial, haven't heard too much of Aragon... except as a brand name.
How much are they charging for their gear nowadays?
Last I remember, they weren't too far off from Krell at the higher end of their product range.
Username: Rick_b
New York USA
Post Number: 908
Skies,
I owned and used pre-Klipsch Aragon amps for years. They are powerful, built like tanks, and reliable. I don't know much about the new amps. If you have a chance to get one gently-used, go for it. They can be had for very reasonable prices. Again, a lot of amp for the money.
Username: Gman
Mt. Pleasant, SC
Post Number: 638
I have an Aragon 2007 amp (7 x 200 watts)and the Aragon Soundstage AV pre/pro. Both units are beautiful and have high quality workmanship. The only downside on the amp is a lack of balanced inputs/outputs. In my system it makes no difference, as I have never noticed any hum.
I was able to get them at a 30% discount at The Sound Seller.
SkieS
$2500 for a Aragon 3002 brand new, I couldn't find any Aragon amps on ebay.
Username: Rick_b
New York USA
Post Number: 914
Go to www.augiogon.com
I see Aragon and their sister amps Acurus, quite often.
