PSB's OR??
Username: Phrapp
I am quite happy with my PSBs Image 2bs, but I have been told other names have more bang for the buck. Better sound quality.
How does PSB stack up with JAMO, Velodyne, Paradyme and Dalquist? Should I move to a new brand or stick with what I have.
Username: Stealth_c
Dublin, CA USA
Post Number: 88
Stick with what you have if you are happy with its sound. Bang for the buck is up to your ears only.
Username: Tevo
Chicago, IL USA
Post Number: 47
I would wager PSB speakers stack up well versus any other manufacturer in terms of price/performance. They make some really good speakers.
And I agree with StealthC, ultimately, value is in the ears of the listener. :-)
jaeelarr
I had a PSB set up about a year ago...it was excellent!!Ive moved to Acoustic Energy and they run about the same in quality.Good choice by the way!
