HK AVR 630 firmware upgrade
Has anyone tried to upgrade the new firmware 5.02 for HK AVR 630? If yes, please give your comments on the new firmware. Is it better? Any problem? Thanks.
vancouver
Yes I did, It took about 1 hour to upgrade the cpu and dsp. I think it is a bit better, no more 2 second delay at start of a song from cd.
I wish Harmon would list the advantages of 5.02 over 4.01!
Bad news! When I started the CPU upgrade, the status stayed at "Erasing.." forever (more than one hour), I shut down the receiver after that, and could not be able to start the upgrade again. The console screen kept showing "WAIT DATA", and I could not turn on the receiver again.
Good news! I still have time to exchange for another one.
Vancouver, how long did it take you to upgrade the CPU part? Thanks.
vancouver
The cpu upgrade took about 6 min, try flashing it again and follow the detailed instuctions. Good luck.
