Speaker watts ....
Username: Subabu2002
Erode,, Tamil nadu,i... India
Post Number: 20
hi all,
my receiver is 100 watts continuous rms with 8 ohms.
i can watch jbl speakers for surrounds.it`s specification is 50 watts continuous/200 watts peak.and it`s recommended amp power is 100 watts.
should i connect this speaker to my receiver?? why this dout because,they specify 50 watts continuous for speaker and 100watts for receiver.
speaker`s maximum recommended amp power is 100 watts.does it is equal to 100watts continuous power of receiver?
please clear my douts
suresh babu
Stealth C
I wouldn't worry about it too much. As I understand it you're more likely to damage a speaker through too few watts than too many. Furthermore unless youre planning to turn the volume up to the maximum, I don't believe it will be running anywhere near the full 100 watts anyways (correct me if I'm wrong).
I personally have run a few cube speakers rated for 75 watts max off a hundred watt amp without any issues but that may just be my stupidity.
mikek
I used the same set-up
100w per channel receiver into 50/200w peak surround speakers
I never had a problem.
Username: Project6
Post Number: 2335
you will be fine suresh!
