Witch movies are 7.1
Username: Cory
I got a 7.1 decoder and have yet to find a 7.1 movie i know dolby Digital has Plus but havn't found any movies with it I know theres EX,ES and then matrix decoding breaks up the 6channel into 2
Does any one know of or herd a 7.1 movie?
Username: Kano
Post Number: 232
There is none. The closest thing is Dolby Digital Ex, which copies the L,R surround channels to the surround back channels.
DTS can have 6 discrete channels.
Otherwise when a 7.1 format comes out you will need a software or receiver upgrade to play it.
