Having trouble finding online vendors for Marantz SR7500... Any suggestions?
Username: Dgurjala
Anybody know of the best place to order the 7500 from? Keeping reading from various posts that it can be found on the web for ~850, but I haven't found this anywhere? Don't think ac4l.com carries it.
If any suggestions, would greatly appreciate it! Also, do you think it is worth it vs the 7400?
Thanks,
Dev
dowdy
www.amusicdirect.com, www.hifi.com, www.electronicsarena.com, www.Accessories4Less.com -- these are the only authorized online dealers. I believe I saw a 7400 on hifi.com for $799.
Username: Dgurjala
Thanks for your reply! Unfortunately of the places you've mentioned, only hifi.com has it for $999, and none of the other places carry the 7500. Still looking for that $850 metioned in review articles.
any other suggestions? thanks!
dowdy
I misread your post earlier, I thought you were looking for the 7400 for $850.
I just purchased a 7500 from Hifi and to me its worth the xtra money b/c of the 4 component input vs 2 on the 7400. I would think if you were to find this receiver for $850, it wouldnt be from an authorized dealer, but that is just a hunch. Good luck w/ your purchase
