Pioneer VSX-D409 'Turning Off'...Please Help
I was playing this receiver and it shut down before i could read what it said on the front. Now everytime i turn it on it stays on for 5 seconds and then says 'poweringoff' and shuts itself off. I've looked everywhere to figure this one out but have found no solutions. Please help!
G-DawG
look in the postings for the vsx-24tx for one. now to your problem I own a VSX-05 and i had the same problem my reciever would flash OVERLOAD on the display and shut off within seconds i thought i had a faulty reciever but it was a short circuit caused by my cat.my advice is too check all of your wires remove them all and if it works reinstall them one at a time.
meek
check the speaker ohms and see if its compatible with the reciever, maybe you have an impedence mismatch and the recieveris overworking itself?
