Troubleshooting Pioneer DVD model XV-HTD510-B
My dvd reicever works fine for everything except when I push the DVD/CD button or the Open/Close button: the display shows "DVD Error" and then the the device goes to standby after a relay cut-off without even opening the door tray.
Do someone has some knowledge about this problem.
I would appreciate your help.
Thank you so much.
