Paradigm ADP 370 Speakers
fatjb
Is ADP 370 worth buying for $600+, when ADP 170 and ADP 70 are available for much lesser price ?
My question is there a big difference between ADP 370 compared to ADP 170 or ADP 70 ? Is it worth spending more money on ADP 370 ? Thanks.
Username: Stealth_c
Dublin, CA USA
Realistically only you can make that decision for yourself.
Username: Riches1
Atlanta, GA US
Post Number: 79
fatjb:
I had paradigm Mini Monitors up front and used paradigm atoms in the rear. Atoms have the same drivers as the ADP 170 for much less cost. Using a direct driver in the rear is also a better setup
for music and works just fine for theater. IMHO, the ADP 370, and most other rear surrounds are way overpriced (to include my own Axiom QS4's).
