A question on subwoofer cables...
Username: Lytalbayre
Post Number: 22
Do I buy into the hype?
Maybe....
I am looking at 3 different ones so far
1. Acoustic Research Master Series Sub Cable 12ft
2. Monster M1000 12ft subwoofer cable.
3. Monster ZBass 100 12 ft sub. cable.
Which one is best? Are they all equivalent? Is there a better one? Is it all just hype and a regular RCA cable will work just the same?
Thanks all.
Username: Nm2285
Delaware
Post Number: 48
Any of them would be fine. I went from a really cheap RCA cable to AudioQuest and heard a difference. This I attribute to the dismal design of the other cable. The only time you'll hear a difference in sound is if you get a bad cable. Either of the brands listed above will make a decent cable even in their entry lines.
Malecai
My subwoofer will stop playing until I physically disconnect from the amp via the coaxial digital cable and plug back in.
Is this a bad cable? This occurs in dvd's, tv and xbox.
