2 JBL Northridge E250 or 1SVS PB2-ISD?
Username: Jake272727
Vernal, Ut Usa
Post Number: 7
whould i buy two JBL Northridge E250 or one PB2-ISD. i want to have great bass for my movies.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 102
Disclaimer: I've never heard either.
Getting two lesser subs only gains you 3 dB of volume. If the sub can go low, adding a second identical one won't help. If the sub doesn't sound good, adding a second one won't help. Also keep in mind that placement for two subs is more complicated since you don't want the bass to cancel out.
I'd get one of the better sub rather than two of the lesser sub.
Vernal, Ut Usa
Post Number: 22
ok im wondering if i should go svs pb2-isd or the hsu vtf3
Username: Heff
Post Number: 126
if you have space and $$$ you can try them both and return the one you like the least.
monkey man jack
If you want great bass try the JBL PSW-112, or the PSB sub sonic 7. Both are 15 inch powered subwoofers, but the JBL has 100 more watts than the PSB.
Username: Bruce_t
Sarasota, FL Usa
I got the pb12-isd/2, man this sub is awesome. I haven't properly calibrated because I'm waiting for my house to be built. But from just testing where I'm staying right now, it shook the house and a light cover in bathroom fell down, and I didn't really have it turned up. This sub rocks! It may be big for some, but then again, size does matter in this sense. Glad I bought it.
