HK AVR210 AUTOselect DTS wont select
Username: Fishcca
Can you help me?
my Harman AVR210 will not auto matically select Dolby
or DTS when teh DVD is is started. I have compatible
Sony with DTS and Dolby and an optical cable. As a
matter of fact it will not let me select them as a
choice manually... It will if I unplug from the optical,
but what good does that do right? Any
suggestions please!!!!??
Thanks!!
fishcca@hotmail.com
Username: Project6
Post Number: 1870
check the menu on your dvd player set-up, not the dvd set-up. Check if it is configured to output DTS and Dolby Digital. Check your manual for details.
Username: Fishcca
Berny Thanks!
Okay, so go to the DVD PLAYER and check out the menu for the output, and make sure I have it set up for the DTS and Dolby output...
BTW I am using a Sony SLV-D300P DVD-VCR Combo as the DVD player if any people have insight on that as well.
Username: Fishcca
k. Just so you know. Berny is right on! I found the manual for the DVD player online and it says that to use these DTS type functions you need to Enable them first, by default it is OFF!
Username: Sinkdrain
Post Number: 62
Yea, I had the same problem about a week ago. I wonder how many people don't even know that they are not getting dolby digital and DTS from their dvd player.
Username: Project6
Post Number: 1876
You'll be surprised. Usually the Dolby Digital is toggled on by default but not DTS.
Username: Fishcca
both WERE set to off by default, I switched them on and it AUTO selected DD and DTS depending on my DVD...
Thanks Guys!
Username: Fishcca
Thanks Guys!
Username: Sinkdrain
Post Number: 65
Yea, and mine had DTS set on but Dolby Digital set to off.
Username: Kano
Post Number: 113
No one mentioned if there's an option between PCS and bittstream, choose bittstream.
Username: Fishcca
Post Number: 7
no bittstream option on mine...
Thanks!
