Paper in the speaker ripping
Username: Zeke2
Columbia, Tennessee U.S.
In th espeakers on my stereo the paper is ripping its only around the edge in the softer sections. I have been told that there is some tape that you can buy to patch that kind of stuff up but i can't find any. i'd like to know what i could do, if the tape would work or if i need new speakers, or if there is any other solutions like haveing the paper replaced or if thats even possible. Thanks if you can help because I have no clue what i should do.
J. Vigne
You can have the speakers reconed or replaced with a new driver. If you will call a shop that handles pro audio in your area they can tell you who can perform a recone. Replacement is a job most people can handle themselves.
Username: Kegger
MICHIGAN
Post Number: 1833
Also partexpress.com sells refoaming kits to do it yourself!
heres a link:
http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&&DID=7&CATID=49&Object Group_ID=373
Username: Project6
Post Number: 1848
What speakers do you have? Do you think they are worth reconing?
