Digital video to PC
Margie
Just what do I need to get my video into my PC? Using new XP with usb's and firewire. Also need instructions on how to do it. Thanks
Username: Kegger
MICHIGAN
Post Number: 334
best thing to do would be to go to your local pc
store and pickup a package for doing just this it
will give you a way to connect and the software
to do waht you want all in one package.
also that wat you know the software should work
correctly with the connection device.
if by chance your in the market for a video card
the ati all in wonders are excelent cards and the
cards come with the conections you need along with
the software.
