Which Hsu?
Username: Tsl90
Edmond, OK United States
Post Number: 34
I have (or will when they finally arrive from the factory) a Rotel 1056, B&W600 series front and center, CCM65 ceiling rear. I'm looking at subs for my 18x19 room with 10' ceiling. I like what I read about Hsu, but am not sure which is the best for my application - probably 75% movies / 25% music.
STF 2/3 - supposedly biggest bang/$
- could stretch my budget (again) and go for STF 3
VTF 2/3 - I like the variable tuning idea
- I'm such a novice I may be too stupid to take advantage of it
- I probably could only afford VTF 2
Anyone have any ideas. Is VTF 2 enough to fill this space? Would a newbie be better served with an STF?
Thanks in advance.
TL
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 133
I comfortably fill my room with a STF-3 (30x11x8) but you have 30% more volume to fill. On the other hand, my sub has to keep up with Klipsch La Scala main speakers (104 to 106 dB/1W/1m).
Tough call, but I would guess STF-3 or VTF-3 is best for such a large room.
Fill the web form with your room sizes on the Hsu site and Dr Hsu will email you a recommendation. He did so for me within a few hours!
Username: Tsl90
Post Number: 37
Thanks. Dr Hsu (do you think it's really him or that they just put that on e-mails to impress you?) says STF-3 or VTF-3. My own paranoia says that a retailer will always recommend one of their more expensive products even if a lesser model would be OK. I was thinking more about a VTF-2 but I guess my budget will settle me at the STF-3.
Thanks again for your input.
TL
Username: Rh1
Post Number: 316
tpl...I would imagine it was in fact him, small company but they produce awesome subs. I think you will be happy with his recommendation either way
Post Number: 137
I concur with vols. I think it's Dr Hsu himself.
Peter
Username: Chuck_m
Cincinnati
Post Number: 13
Hey TPL -
It sounds like you're in the gray area between the 10" & the 12".
For what it's worth, I was getting the STF-2 for my 13 x 20' room. Mostly music in my case, I couldn't see the exta $100 for the tunable-port VTF series.
But SVS just brought out thier first 10" sub, & I ordered one of these instead of the Hsu. It has more power (300 watts) than the Hsu, & better specs. Is available in 4 finishes for $399 until Nov 1. Suggest you check it out - model PB10-ISD.
Gotta move fast to get the pre-order price, though.
Have fun!
Username: Tsl90
Post Number: 42
Dick
Thanks for the info. I confess I'm intrigued. Unfortunatedly my STF-3 should arrive any day. I'm purposefully not researching this as I'm prone to buyer's remorse anyhow...
TL
Post Number: 183
Dick,
It always sucks when something comes out right after you buy something, but I'm quite sure you'll be please with the STF-3. Great on music, rock on music.
Let us know how it goes!
Peter
Username: Chuck_m
Cincinnati
Post Number: 14
TPL - I agree with Peter.
You'll have nothing to regret with the STF-3.
There's always something new on the market, but if you have something of quality like the STF, you can be assured it'll sound great. Enjoy it!
Username: Tsl90
Post Number: 44
Thanks again all.
I'm looking forward to my Hsu. Delivery expected tomorrow per Fed Ex. It's not that I worry I won't like it, its that there's a bargain I missed. My budget on this project exploded and saving a few hundred on something would have given me something to brag to the wife about. Oh well...
TL
Username: Beaver
Post Number: 9
i just bought vtf3 mk2 simply put its worth every dollar. sharp clean bass its amazing. cost me 1100cdn and i don't regret one dollar spent. for anyone wanting a excellent sub i would definitly recomend it. i had 2 10inch jbl subs before and this puts them to shame. hope that this helps you out with your choice.
Username: Tsl90
Post Number: 45
Hooked my STF-3 up this weekend. What a difference! I wasn't sure I missed much without it, now I'm startint to appreciate it a lot.
Thanks again all.
TL
Post Number: 244
Glad to hear it! Great on movies, great on music. I placed mine behind my couch and the impact is strong without being boomy. If the have the Eagles' DVD "Hell Freezes Over", the kick drum is incredible.
